2tc and 3tc parts/ Corolla parts doug thorley header
				ministock92
i have a lot of 2tc and 3tc parts. Anything 2ct or 3tc is for sale have heads one of which is a old 2tc non egr port $250 and other heads between 100-200 depending on what all is there. Have two 3tc cranks 150ea. Complete stock 2tc bottom end with 5 speed trans $300. Brd cam $80. Doug Thorley header has a few dents $200 a hooker super comp header $50. non 5 finger intakes have 3 two with stock carbs on them $40ea. valve covers few different designs $30ea timing covers $25ea oil pans $30ea. Have a 10 bolt 330 ring and pinion a 8 bolt 410 hogs head a 8 bolt 373 hogs head $100 for ring and pinion $150ea hogs head almost complete (missing a brake drum and few other parts) 10 bolt rear end with a 410 in it have some other parts as well just ask I might have it. also have a complete race ready 3tc motor has 40 over wisecos with eagle rods block decked to.000 stainless valves bronze guides brd valve springs 5 finger intake with a holley 350 carb hardened push rods cant remember cam but bigger can adjustable cam gear everything new 4 races ago great motor $3000. any questions just ask thanks. all parts located in Asheboro NC
						Re: 2tc and 3tc parts/ Corolla parts
any stock 5 finger intakes and can I see a pic of 8 bolt 330 thanks
				ministock92
Na no five fingers and im sorry i messed up 330 ring and pinion is for 10 bolt. Cant post pics but can send pics by txt.
						Re: 2tc and 3tc parts/ Corolla parts doug thorley header
Any later model valve covers?  The one that doesn't use the flat gasket?
info on the 10bolt rearend ?
				ministock92
Yea have one of those vavle covers with a new gasket to go with. 10 bolt rear from a early 80s celica has 410 hogs head is all stock everythings there but one brake drum.
Thats all i know about it.
PM sent i want the headers
I pm'd u my ## need pics of rearend
						- Teun
- Contact:
The brd cam, will it fit my 2t? also, what are the specs?
							--=...Lowest BHP title owner...=--
Do you have any exterior parts for a TE72 1982 2 door sedan Toyota Corolla. I need fenders on both sides, shift boot, console, window regulator, or doors with working windows.
