Rearend choice celica El salvador
Re: Rearend choice celica El salvador
My corolla have an Toyota van Hiace 95
Check the build http://3tcgarage.com/viewtopic.php?f=27&t=202
elvarto
Post by elvarto »
is possible to do this, narrow diff,how
elvarto wrote:is possible to do this, narrow diff,how
You will need to repline the axles or get new ones
http://www.garagejournal.com/forum/show ... hp?t=46025
elvarto
Post by elvarto »
how much hp support mazda pick up diff
elvarto wrote:how much hp support mazda pick up diff
The mazda pickup also Ford courier have prove not to break at 400hp
elvarto
Post by elvarto »
lsd? or after market parts?
elvarto wrote:lsd? or after market parts?
If know since is ford wide ration available don't know the center whether the use lsd or weld it together
elvarto
Post by elvarto »
i read that the first generation rx7 lsd fit"s in a mazda b2000-b2200, is true?
elvarto
Post by elvarto »
which axle ratio is better for turbo application 3.909:1 3.307:1
elvarto wrote:i read that the first generation rx7 lsd fit"s in a mazda b2000-b2200, is true?
Eso no lo se bro ;)
