Rearend choice celica El salvador
Re: Rearend choice celica El salvador
My corolla have an Toyota van Hiace 95
Check the build http://3tcgarage.com/viewtopic.php?f=27&t=202
is possible to do this, narrow diff,how
You will need to repline the axles or get new oneselvarto wrote:is possible to do this, narrow diff,how
http://www.garagejournal.com/forum/show ... hp?t=46025
how much hp support mazda pick up diff
The mazda pickup also Ford courier have prove not to break at 400hpelvarto wrote:how much hp support mazda pick up diff
lsd? or after market parts?
If know since is ford wide ration available don't know the center whether the use lsd or weld it togetherelvarto wrote:lsd? or after market parts?
i read that the first generation rx7 lsd fit"s in a mazda b2000-b2200, is true?
which axle ratio is better for turbo application 3.909:1 3.307:1
Eso no lo se broelvarto wrote:i read that the first generation rx7 lsd fit"s in a mazda b2000-b2200, is true?
