Alternator wiring.
gotae86
Alternator wiring.
Post by gotae86 »
Hey guys,
I bought an engine that I'm swapping into my AE86 and I need some help wiring up the alternator. I have 2 different ones. One has a 2 pin connector and the other has 3 pins. Any and all help is greatly appreciated.
3 pin
2 pin
Thanks,
g
Re: Alternator wiring.
The 3 pin look like an external regulator alt
The 2 pin intern regulator
1* which one do you want to use on youre 86 ? the pin 2 ?
gotae86
Post by gotae86 »
The 2 pin alternator is what is currently installed. :)
On the 2 pin alt is there an letter stamped near the plug ??
L or IG or S ?
gotae86
Post by gotae86 »
I'll have to take a closer look when I get home later.
gotae86
Post by gotae86 »
What if I were to use the 3 pin alternator?
gotae86 wrote:What if I were to use the 3 pin alternator?
Thats going backwards ! You will need to ad extra few wires so it can connect to the external regulator
If you know what's stamped on the alt i will guide you to make it work.
gotae86
Post by gotae86 »
Ah, I assumed that 3 pins would have been more up to date than a 2 pin. I'll pull it out tonight and take a picture.
You learn fast :mrgreen: check the wire diagram upper is external lower internal regulator
charge system.jpg (56.41 KiB) Viewed 14766 times
gotae86
Post by gotae86 »
Thanks for that diagram. It's makes a little more sense now.
I found the stamping on the alternator, L and IC.
